Samsung Galaxy S22 Ultra worst Battery draining issue
(Topic created on: 04-28-2022 05:17 AM)
waqasfadal
Beginner Level 3
I bought the very new high end Samsung Galaxy S22 Ultra device which came with a built-in rapid battery draining issue such that the phone goes down from 100% to 20% in 6 to 7 hours that too on screen off time.
What do I need to do with the phone very high end and having this drastic issue.
Means my more than 1000$ lost in the ocean?
Somebody help.
5 Comments
MrAmJay
6 7 hour is enough for very high end hardware phone.
waqasfadal
Beginner Level 3
Even on screen off time?
SamsungTec
No if screen off it should be for 23 hours my s 21 ultra stay this time from last year till today go to Samsung branch service and let them check and replace battery if it's needed and it will cost you here in Emirates almost about 900 Derham
shiv7688
There may be some software glitch.....better take it to nearest Samsung Service Center and ask them to format and reload the software via computer.
Please make sure that you take backup of your phone data. I hope this will resolve your issue.
Could you send a screenshot of your screen time with battery usage data? My phone does not loose more than 2 percent with the screen off. My always display is off and not on vibrate.
