Samsung 45W charger charging in normal speed
(Topic created on: 10-22-2024 11:47 PM)
Pradeep1428
I own a sammy S24 Ultra, i brought a 45W samsung charger along with the device. I have been charging the device with the same charger from the day 1 and mobile used to charge in Super fast 2.0 mode with Violet circle light while plugging in. Suddenly from this morning when i charged my device i noticed that it is charging normally with green colour circle light while charging! I tested it with my Samsung s20 FE its charging in super fast mode, So the charger is not faulty.
I doubt if its a software problem or is there some settimgs in the device which got changed . The purpose of buying this charging brick spending huge money is not resolved.
Dear community member and Samsung care you have any update out idea to resolve this please respond back ?
16 Comments
Akshay_Sharma
Samsung official 45w PD charger .....If you do not use the original charger then it will not support fast charging even after turning it on
Not applicable
Use a Samsung 45W charger with the cable that comes with the charger. It will provide super fast charging 2.0. Otherwise, we use a 45W power adapter with the cable that comes with the mobile; it will be only super fast charging.
JamesTh
Just to be sure, borrow any other 25-watt or 45-watt Samsung original charger from someone and try again. Who knows, your phone might not be recognizing your particular charger.
Pradeep1428
This was the charger which i was using for the last 6 months in sfc..
Nijju786
Bro, I had this same issue with my previous phone, the Samsung Galaxy M52 5G. The solution I found was to replace the charging connector flex/PCB board. I don't know how, but the Type-C pin was damaged at that time. Did you put something in the phone or was anything stuck in the charging port?
Pradeep1428
No bro!
Mr_Yasir
The changeing cable given in the box supports only upto 3 ampere.
You have to buy a 5 ampere cable to charge your phone upto 45 watt, It will show super fast charging 2.0
