Same problems with S20 FE even after 2.5 months with all updates..
(Topic created on: 03-03-2021 10:17 PM)
Neelanchal
1. Super fast battery drainage
2. overheating on charging and video calls
3. Slower charging with inbox charger
4. Ghost touch on brightness adjustment
5. Flickered scrolling on all apps
6 Comments
They should rename the device from Galaxy S20 Fans Edition to Galaxy S20 Bugs Edition.
Maddy210
exactly 😂
AbhishekPuri
clear cache partition
Step Clear Cache Partition
step 1
Turn off your phone ...Connect your phone to laptop/pc with a type-c cable.
step 2
Press Volume up and power button (also press bixby button if present) at the same time .
step 3
Keep it pressed until samsung logo appears on your phone.
step 4
Then a list of your options will come on your phone..
Go to Clear Cache Partition option by navigating through volume buttons.
step 5
After selecting Clear Cache Partition option,then click power button once.
step 6
Once Cache is cleared you will be taken to first option..Then again click power button to restart the phone!
after that go to device care than battery section and click on background uses limit than turn on put unused aaps to sleep and come back and click more battery settings and turn on adaptive battery.
than come back device care interface and click on 3dot than click on automation and turn on adaptive power saving.
Maddy210
tried all brother many times...even after every update doing the same...but sadly it never worked..S20FE is piece of s h i t
f62_CA
Expert Level 3
Will it delete all of my data like a factory reset
AbhishekPuri
Yes
