11-09-2025 01:20 PM (Last edited 11-09-2025 01:26 PM ) in
Galaxy S- Mark as New
11-10-2025 01:06 PM in
Galaxy SDear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concern. Also, we are taking your feedback regarding this matter.
● Kindly check physical condition of your camera lens.
● Kindly clean the camera lens by microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
11-10-2025 01:38 PM in
