Few problems after ui 7 update and nearly a month
(Topic created on: 05-27-2025 09:53 PM)
singh_amrit_001
Screen lock
When I directly lock my phone while using any app or even in home screen . It takes nearly a second to get lock . It doesn't lock instantly as it should be .
My home screen is fully customized using diy screen so may be .
Notification panel pull down
If I am using any app and out of the sudden if i pull down notification bar then it takes 1.5 or 2 second to come down . No matter it is right side one or left side one . But it only happens first time afterwards it will at its usual speed .
Battery
Battery toh everyone know how **bleep** up it is . I thought after security patch it would better but ho changes . In my s24 base model 1 % last around 3 mins ( not while gaming ) . Just while normal ussage like scrolling instagram , watching yt videos or while seeing downloaded videos in mx player .
2 Comments
bhghwan
Aod n now bar of ui 7 ruined whole experience of screen specially lock screen
cs_member10
Dear Samsung Member,
As you are facing multiple issues with your device, we kindly ask you to share the log file with us. Additionally, if you have any video clips or images that illustrate the problem, it would greatly enhance our understanding.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
