S6 150 MB update received & battery problem
(Topic created on: 08-15-2017 06:07 PM)
technoBoy
Today I checked my phone and got 150 MB update . Its not a security patch update its still 1 July . The only change I noticed was new Device Maintenance icon (check in 1st screenshot ), can anyone tell what other things have been added or fixed .
I am facing fast battery drain on my S6. What about others is it a software issue .... I have replaced the battery in January. If you sum up the usage percentage in battery section then total does not match to the real batteryb727cc38-13f9-4b7c-af37-74b47e2f42c3.jpg
14 Comments
Vinoth_DP
Grace UX 😍
Bizzle
same problem
aadesh
i have received no such update
technoBoy
its for Galaxy S6 .... check it manually
aadesh
im owning s6 edge
GauravK21
Can you please add Screenshot of Screen On Time ..✌✌
technoBoy
screen on time ??? elaborate , not getting it
Naren88
uninstall Facebook apps , Lightroom which are showing up in the list of battery consuming apps. Do a cache partition wipe and try .
Naren88
dumpster as well
