S25 ultra network problem both sim not showing 5g
(Topic created on: 02-04-2025 02:42 PM)
NitinParkhi
My new s25 ultra not showing both sim 5g network 😑
7 Comments
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode also optimize your's device in device care too also clear catche of all apps manually then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
naviaz
Congrats for new phone!
My 25U shows both sim 5G.
Try restarting & after a restart a notification tells you to tap & update both sims, try doing that & finally try reset network settings.
All the best with S25ULTRA 👍
Arya111
Fix Next Update
Aadii_18
Both my sims are working showing 5G on my S25U. Doesn't look like a software issue. Maybe check the network connections and reset
Akshaycell
I had network reset my S24 Ultra last month and after that it stopped getting JIO 5G. As I started to wonder and feel worried, in 5 mins, the 5G network came back. Maybe, you can give it some time in a 5G network. Please do reply if this helped.
cs_member10
Dear Samsung Member,
Thank you for reaching out to Samsung Customer Support. We appreciate your concern and would like to assist you in resolving your issue.
● 5G in your Galaxy device: https://www.samsung.com/in/support/mobile-devices/how-to-use-5g-on-your-galaxy-phone/
● Network optimization: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
Note: kindly contact your network service provider once to make sure there is no issue from their end.
