S24Fe Network Problem
(Topic created on: 07-21-2025 07:25 PM)
VaRuNDeVK
Network not working properly all the time.
After the update, the problem started. Is anyone else facing this issue?
6 Comments
goodthings
Vishaloza1112
Listen my friend 🧡 I admire ur job, i appreciate, but this mother fuqr Samsung is not doing its job very well.
Go and chek how many time i had reported and see what they doin Shii## in every time.
goodthings
You're welcome to here.
alllen1222
No I havent
BiRdMaN
Send an error report along with log files to customer support through this members app and Samsung will add/fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful I'd appreciate it if you could Accept it as a solution Thank you 😊
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly visit this mentioned link to resolve your issue.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
