3 weeks ago in
Galaxy S- Mark as New
3 weeks ago in
3 weeks ago in
3 weeks ago (Last edited 3 weeks ago ) in
3 weeks ago in
Galaxy SI think it is a failure of Samsung
3 weeks ago in
Galaxy SDear Samsung Member,
As per your query, we want to inform you that this is not a bug or issue, It happens due to the Adaptive brightness feature enabled on your Samsung device, this feature allows the touchscreen to automatically adjust its brightness based on the surrounding environment, you can follow the below steps for resolve your device issue:
① Change the display mode to ‘Light’ mode. (Settings > Display > then select the ‘Light’).
② Alternatively, Adjust the display brightness a little bit brighter. (Settings > Display > adjust the Brightness to a brighter level).
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
We have also noted down the feedback. We are continuously working for making our products better and more efficient.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
3 weeks ago in
Galaxy SNone of that works. I even made sure all backgound apps that might be causing heat were "off". Now kindly explain to me why I have a $1300 "mobile" smartphone that I cannot use outside, where I happen to spend most of my time for 3/4 of the year???? Not happy with Samsung right now.
