S24 Ultra Display Issue
(Topic created on: 05-26-2024 05:18 PM)
RAMULTRA24
Hi,
I am using Samsung S24 Ultra and Unable to use even 10 minutes in Sunlight...
After using mobile for 3 minutes or so the Screen is getting Over heated & Unable to see the Display as it will become DIM after that it will become Normal only after you go it Indoor..
Unable to Use it even 10 Minutes in Sunlight Displayyyy..
Even we checked in My friend's S24 Ultra, Similar Issue in that Mobile also....
it's BIG ISSUE in a Samsung S24 ULTRA Flagship Mobile But Samsung was Unable was not taking this issue very Seriously and Fixing it !!!!
This Issue is Not there in S23 Ultra and it's Display is best than S24 Ultra...
Even 10 thousand mobile we can use as much as time in Sunlight and it's Display is Super in Sunlight...
But Purchasing S24 Ultra Flagship Mobile of Samsung with Lakhs of Rupees But Unable to Use for even 5 minutes in Sunlight...
Immediatly Samsung need to fix this or Recall All S24 Ultra mobiles to fix this Issue in Mobiles
If Samsung Unable to fix this Issue, It need to Refund all the price of the Mobile to effected S24 Ultra mobile Users...
8 Comments
KushalN
Bro meeku battery yela vundi s24 ultra lo I'm getting around 5hrs ? For u
RAMULTRA24
Check in your mobile regarding above Issue, Most of the S24 Ultra mobiles had the issue and do update your review here
Let us Raise Our Voice to Samsung to fix this Big Issue
RAMULTRA24
Mee too getting only 4 to 5 hours Screen on time...
I am using in Battery Saver mode in most of the time
KushalN
Ya bro 4 to 5 hrs is very bad
S23 ultra has a better sot when compared to s24 ultra
Not applicable
My s24 ultra have same problem not mine even every s24 ultra have same problem. the display was not bright even for 3 minutes in direct sunlight.
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share the same video clips for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
RAMULTRA24
Sir
We sent many times but no Solution from your side....
Many S24 Ultra Users facing this issue..
So Dissappointed
khansa286786
Nice
