06-01-2024 08:36 AM (Last edited 06-01-2024 06:37 PM ) in
Galaxy SEven After May 2024 Update also the below ISSUE was not fixed..
So Dissappointed 👎 👎 👎
SAMSUNG Urgently need to fix below Issue....
Even I am unable to use samsung S24 Ultra even 10 minutes in Sunlight...
After using mobile for 3 minutes or so the Screen is getting Over heated & Unable to see the Display as it will become DIM after that it will become Normal only after you go it Indoor..
Unable to Use it even 10 Minutes in Sunlight Displayyyy..
Even we checked in My friend's S24 Ultra, Similar Issue in that Mobile also....
This Issue is Not there in S23 Ultra...
The S24 Ultra Display is very bad & Worst Display even when you compared to S23 Ultra also...
it's BIG ISSUE in a Samsung S24 ULTRA Flagship Mobile But Samsung was Unable was not taking this issue very Seriously and Fixing it !!!!
Even 10 thousand mobile we can use as much as time in Sunlight and it's Display is Super in Sunlight...
But Purchasing S24 Ultra Flagship Mobile of Samsung with Lakhs of Rupees But Unable to Use for even 5 minutes in Sunlight...
This is Very very BIG ISSUE in the Samsung Flagship Mobile S24 Ultra.
So Surely it's Samsung Responsibility to fix this Issue
or
Else Do Recall All S24 Ultra mobiles and change Displays
or
Refund to all effected S24 Ultra users
06-01-2024 08:44 AM in
Galaxy S- Mark as New
06-01-2024 09:00 AM in
06-01-2024 05:43 PM in
06-01-2024 06:36 PM in
Galaxy SBut In Reality it's not Working Properly for even 5 Minutes also in Outdoor Sunlight....
06-03-2024 12:28 PM in
Galaxy SDear Samsung Member,
As per your query, we request you kindly share the log file. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
06-03-2024 12:56 PM in
Galaxy SBut You are Fixing it
