S24 ultra Display black dot problem
(Topic created on: 10-02-2024 09:53 PM)
umraoyogesh
9 Comments
sangram21
Online or offline ??khya se buy kiya tha?
umraoyogesh
Offline
Kuldip_india
Go to samsung care they will replace the display
sangram21
Immediately go care...its free to replace display.
umraoyogesh
Ok
itmerk
Any accidentally drop??
umraoyogesh
No
umraoyogesh
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Kindly restart your device once: To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
