S24 heating issues and as always poor battery life.
(Topic created on: 10-19-2024 01:17 PM)
TribalxChief
Ever since I have updated my S24 to the October patch, I have noticed abnormal heating in the phone. Even in basic tasks like Instagram usage, and when I use mobile data (4G), and gets warm when I use Twitter. I hope they fix the heating issues ASAP.
35 Comments
TribalxChief
Stop being a lameass teacher, I definitely know everything more than you. Your stupid comment was unnecessary, that's why I asked what are you trying to do?
Mayur000
Your ego is bigger, you can't learn and respect anyone.
So go to hell.
TribalxChief
Beta tu F04 rakkha hai, galti se S24 waale area mein aagya hai, chal ab ja.
cs_member8
Dear Samsung Member,
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send.)
DrRajanThakur
My s24 ultra working fine.
#Like Butter.
TribalxChief
Sir, aapka Ultra hai, 5000MAH battery, hum chhote aadmi hain S24 hai humare pas jiski battery 4000MAH hai.
