Samsung galaxy S22 ultra one ui 7 update problem solution please
(Topic created on: 05-12-2025 02:03 AM)
shanisingh5838
Samsung galaxy S22 ultra one ui 7 update problem solution please.....?
1 battery drain problem
2 heating problem
3 hang problem????...please solve😮💨🥹😭🙏
One ui 6.1 update not problem no battery drain no heating problem and no hang😭🙏😮💨🥹.....????
1.I'm not use always on display...?
2 I'm use battery protection 85....?
3 power saving use ....?
4 I'm use deep sleeping apps...?
5 motion smoothness standard 60 hz ..?
6 Adaptive brightness no use Extre brightness no use .....?
.....but battery drain problem....???
......I'm sharing 5 pics......????
......please solve ...........????? 🙏 🙏 please solve 🙏 😢 😔........
I'm use off high settings off all....but battery drain no solve.......😭🥹😢🙏😭
13 Comments
Use battery protection at 90 you'll get good result.
Nai mal ra hmm bhai
amit1275
Do a full factory reset. I do it once a year and my S22 ultra get me a 1.5 days battery life on normal usage.
Bhai is sa kuch ho sak hmm Dana bhai ...
wipe cache partition
Bhai wipe cache partition sa kuch ho sak hmm
akashbayyana
Yes this May help you
Acha ji
JungkookA16
battery backup kitna aarha hai?
