S24 Ultra battery & performance issues
(Topic created on: 2 weeks ago)
Chirvii
After the recent July update , my S24 Ultra performance shows a significant drop in performance in benchmark by atleast 20% than the normal and even the battery backup , charging speed deteriorated.
6 Comments
BiRdMaN
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
goodthings
goodthings
You're welcome to here.
vitalpivex
Same I've also experienced the same issue of the overheating and performance issue in my phone i also have the S24 Ultra. Firstly i thought it may be the refresh rate issue so i also used my phone in 60 fps with normal uses like chatting, watching movie ,listing music but still i experienced the same issue in battery now a days i need to charge my phone 2 to 3 times a days .
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
1. Galaxy device Battery drain issue: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
2. Galaxy device performance issue: ● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third-party applications.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third-party accessories.
● Kindly disable Power saving mode( if enable).
● Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
Chirvii
Instead of doing such things...may be I can reset the device and throw it away....
What's the purpose of buying a costly flagship and using it like entry level device !
Stupid response from the support team
