Recent Update After Effects – Battery, Heating & Camera Issues
(Topic created on: 08-08-2025 07:29 AM)
sahillohraa
Dear Samsung Team,
After the recent software update, my device performance has dropped significantly:
1. Battery Life: On heavy use, the battery lasts only 2 to 2.5 hours.
2. Heating Issue: The phone heats up quickly even during normal usage.
3. Camera Quality: The camera performance has become very poor compared to before.
All these problems started after the recent update. Honestly, if this was the performance from the start, I would have preferred going for an iPhone instead.
Please fix these issues in the next update as soon as possible.
Thank you.
4 Comments
BiRdMaN
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As you are facing multiple issues with your device, we kindly ask you to share the log file with us. Additionally, if you have any video clips or images that illustrate the problem, it would greatly enhance our understanding.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
