Naitik17
02-29-2024 10:54 PM in
I am having a battery issue with my s24 charging very slow on 65 watt charger and draining within 6 hours of performance. I need a solution for this.
3 Comments
jay-patel
02-29-2024 11:00 PM in
After the update, I've noticed a significant battery drain issue.
Previously, I was able to achieve over 9 hours of screen-on time, but after the update, it has dropped to 6-7 hours.
Already rise complain via samsung member>Send error report and samsung website via mail.
rajtamil1988
03-01-2024 01:36 AM in
The S24 is only compatible with a 45W charger. Using an unbranded or overcapacity charger may reduce the battery life of your device. It is recommended to use only Samsung original chargers.
Pkumar28
03-01-2024 08:57 AM in
Dont use any other power adapter which is more than 45W
