S22 Ultra-UI 6.1: Battery Issues
(Topic created on: 05-19-2024 11:26 AM)
Taufeeq8282
Guys, Anyone facing fast draining issue? My phone is not giving even 4-5hrs backup on normal use.
Also last 15% of battery is not giving 5 minutes backup.
Guys suggest if any
6 Comments
WarisS22Ultra
Not facing such issues
Ashru
My S22 plus is exactly performing same
Too much battery drain after 6.1 update
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Taufeeq8282
All tried, found not useful
amit1275
I am not having any issues. Actually phone is cooler and battery lasts more than a day.
Ajay_das
Call to customer care 1800407267864 Complaint dere battery draining issue, say next update plz recover
