Resolved! Solved
S24 ULTRA πŸ”₯ overHeating issue πŸ”₯
(Topic created on: 04-11-2025 11:15 PM)
MrVishal69
Kya apka bhi S24 ULTRA Flagship smartphone videocalls karte time overheating horha hai??
Resolved!
12 Comments
cs_member10
Dear Samsung Member,
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
8. If the issue is still not been resolved, Reset the device:
IMPORTANT:
β€’ Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
β€’ Remember google password before resetting the device because it is required during initial setup.
β€’ If you do not remember it, then reset, (Forgot password) your google account.
β€’ For this:
β€’ Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
goodthings
goodthings
Your's most welcome to here.
