S24 ULTRA BATTERY
(Topic created on: 08-21-2024 06:31 PM)
asp1495
Good day everyone
Hope you are well??
I got this phone a week ago..but the battery runs down quickly when using it...I don't know is it because it's still new or what..Anyone else with this problem??
And I am still on July security patch...I haven't received the August update..my S23 Ultra has already the update
asp1495
Okay thx...will do
asp1495
Hey.. Today marks 11 days, sins I got the phone...What suggestions do you have for me?
Neolyn
Can you attach a screenshot of the Battery Care in Device Care.
Follow this direction in Settings.
Settings > Battery.
asp1495
My phone was not charged full.. but it went down quickly in 3 hours' time.. from my last charge, or am I overreacting ???....My S23 Ultra's battery felt better than my S24 Ultra's battery... Maybe give is more time?? Like a month???....and then do you know how I can reset my camera on S24U because it struggles with nearby shots, etc????
Neolyn
I can assist with putting background apps that are draining your battery to sleep.
Yes I can assist with resetting your camera. Is it the Samsung Camera app you are referring too.
asp1495
Thank you...will do it...
asp1495
Hey...sorry to bother you...I wanted to tell you after I hot the August update Monday...my battery improved a lot...I see now what the lady said in the last comment..Mobile data eats your battery....With WiFi on I will get almost 2 days if I use the phone light...if I use it a bit heavy then only 1 day and 4 hours....and with Mobile data like today..will only last me 1 day with maybe a bit of hours...Yeah I can switch 5G off..but then why did you purchase a 5G phone if you are just going to turn it off...
Neolyn
Hey. You have also received the August update. I have also seen battery improvement on my phone. Glad to hear that you have too.
Turning of 5G only prevents your phone from using 5G Mobile Network not 5G Wi-Fi, but if I buy a 5G phone I would also make use of it. I haven't really used my phone today, but this is my battery usage.
asp1495
So you only charge your phone to 80%...not to 100%???....Didn't know that...so then there is no actual reason of switching it off then...
Neolyn
I use it, but I turn it off if I know I am not going to be near a charger in 24 hours.
I use it because I plan on keeping my phone for 4 years. I am not sure about you. It helps slow down battery degradation over the long run.
