BATTERY QUICK DRAINING AFTER ONE UI7
(Topic created on: 05-12-2025 12:39 AM)
Shettoh
Hey guys are you experiencing the same on S24 ultra ..my battery is draining so quick it can be empty after 7 hours of use
7 Comments
Wipe your phone and start afresh then go to YouTube and search for battery saving tips and use as much as you can. You'll be glad you did. I had the same issue on my s24. Samsung is aware and should be fixed in the may patch
the_riot
Give it tym to settle it will go back to normal
Amos-Banda
Is it only is s24 or other samsung devices t
Iampita
Even my S21 ultra is draining faster
Even on my S24 fe its draining
Ria_BG
Same here s24 ultra battery draining fast
TMEN12
I'm experiencing the same 😮😮😮
