S24 Heating and Battery consumption
(Topic created on: 05-18-2025 05:07 PM)
Shubh09desh
Hi people.
After the latest update of One Ui 7 and OS15 , I am facing issue of excess heating of my galaxy S24 bought in January 25 and also the battery consumption has increased. I guess this increased battery consumption is linked to heating of device.
Please do let me know who all facing similar issue.
@samsungindia requesting an update to stablize the ONE Ui 7
6 Comments
Samsung_OneUi
Our S24 heats only little while gaming otherwise not heating
nyggeeballs
Same issue with me, i dont even play any games on my s24, but still phone heats excessively and much battery drain
Yash09sharma
Facing the same issue
alex_8
Same with S24+, is Samsung really care customers
venu3617
I am also using samsung s24 plus normal usage heating his heavy only on speaker part
I am purchased last 20 days back
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
