03-19-2024 11:55 PM in
Galaxy S- « Previous
- 1
- 2
- Next »
03-20-2024 12:30 AM in
Galaxy S- Mark as New
03-20-2024 12:33 AM in
03-20-2024 12:35 AM in
03-20-2024 12:36 AM in
03-20-2024 12:37 AM in
03-20-2024 01:17 AM in
03-21-2024 10:27 AM in
Galaxy SDisable Wi-Fi, GPS, Bluetooth, and other unused features when not in use. To do this, swipe down the notification panel on the home screen and toggle off Wi-Fi, GPS, Bluetooth, and other connectivity options.
- Check for Network Fluctuation:
Ensure that your device isn't experiencing frequent mobile network fluctuations or low network signals in your area. These conditions can significantly drain the battery. We recommend avoiding usage in areas with poor network coverage.
- Set your device's display brightness to auto mode if available. Additionally, adjust the screen timeout settings by navigating to Settings > Display > Screen timeout and selecting the minimum screen timeout option.
- Check for any apps or interfaces that are consuming excessive battery power using the device care feature. Update these apps or refrain from using them if possible.
- Close all background running apps when not in use to conserve battery life.
- Ensure that your device is running on the latest software version. If an update is available, install it to address any potential software-related issues.
- Reset Your Device.
03-21-2024 10:48 AM in
- « Previous
- 1
- 2
- Next »
