S24 Battery Drain
(Topic created on: 03-19-2024 11:55 PM)
arslmaqs
AoA Guys, what is the battery backup of S24?
I am using Exynos version and hardly get 4.30 to 5 hours of Screen On Time. I am using 120HZ adaptive display, AOD (9am-6pm) and mobile data.
How to improve this??
#GalaxyS24 #S24 #Battery #BatteryDrain
18 Comments
Theprofessor18
There is a option for making the device light performance, settings->device care->performance profile
arslmaqs
Brother what's the point of getting a flagship If I can't use it to maximum potential?
Theprofessor18
Very true.
Wa Alaikum Assalam!
The battery backup you're getting on your Galaxy S24 with the Exynos version (4.30 to 5 hours of Screen-On Time) is slightly below average, especially considering your usage of 120Hz adaptive display, Always-On Display (AOD) from 9am to 6pm, and mobile data.
Here are some tips to improve your battery life:
1. **Lower Display Refresh Rate**: The 120Hz refresh rate is great for smoothness but consumes more battery. You can try lowering it to 60Hz for better battery life.
2. **Reduce Screen Brightness**: Lowering the screen brightness can significantly save battery. You can also use Adaptive Brightness or set it manually to a lower level.
3. **Turn Off AOD**: Since you're using AOD for a long period, turning it off when not needed can save battery.
4. **Restrict Background Apps**: Some apps might be using background data unnecessarily. Go to Settings > Apps, and check which apps are using the most battery in the background. Restrict or optimize their background activity.
5. **Location Services**: Use location services only when needed. High accuracy modes like GPS consume more battery.
6. **Battery Saver Mode**: Enable Battery Saver Mode from Settings > Battery > Battery Saver. This will limit background activity and some visual effects.
7. **Disable Unused Features**: If you don't use features like NFC, Bluetooth, or Wi-Fi scanning, turn them off.
8. **Check for Updates**: Sometimes updates include optimizations for battery life.
9. **Battery Calibration**: Occasionally, calibrating your battery by letting it drain completely and then fully charging it can help.
10. **Factory Reset (if needed)**: As a last resort, if the issue persists and you've tried everything, a factory reset can sometimes resolve deep software issues.
Implementing these steps should help improve your Galaxy S24's battery life.
arslmaqs
Brother I am almost doing everything you mentioned. I switched my phone through Smart Switch and then someone recommended that I should not have done that as old apps data drains battery.. So I did the factory reset as well and installed every app individually.
The only thing left to do now is battery calibration.
arslmaqs
Is it safe to do so?
Yes
Before using this code, it stopped the Auto tracker
