S24 Ai Problem
(Topic created on: Friday)
DeviLJin01
Ye sala Background me on hi rah raha h bnd hi nhi ho rha ?
5 Comments
Batmania
Tumhara phone aab apne aap kaam krega bro. Wo AI brain bna rha hai khudka. 😂
DeviLJin01
Ha bhai sungsung wale aate to unke piche dal deta AI
DeviLJin01
Kisi kaam ka to h nhi
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that AI Core is a background service that can provide AI functions to other apps after running locally on the device. You cannot remove the apps from the background, it will run automatically in the background, and you can only force close the apps from the screen.
DeviLJin01
Isse mera battery drain ho rha h uska kya
