Fix problem for Ai sketch to image
(Topic created on: 07-12-2025 01:08 PM)
wariz503
There is no option AI sketch to image plz fix it on samsung s24 ultra
6 Comments
BiRdMaN
Send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
wariz503
Thank you 😊
goodthings
goodthings
You are welcome to here.
KAJAL123
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
