S23 ultra green tint on low brightness issue
(Topic created on: 04-09-2024 11:58 PM)
Shawn10
Does anyone have green tint on low brightness mode in S23 ultra? Mostly visible in WhatsApp and google
To check if you have this issue, first put the lowest brightness in your phone and open WhatsApp.(it should be in dark mode) . The entire screen will have an green tint on it. Does anyone else face this issue. I have updated to One UI 6.1.
11 Comments
RajivKapoor
bro i faced green line and this same green tint issue, had to get my screen replaced
Shawn10
Can resetting the device resolve the issue?
Shawn10
I have updated to one UI 6.1
cs_member10
Dear Samsung member,
As per your query, kindly follow the easy troubleshooting steps which might help to solve the issue.
Power OFF Galaxy smartphones and turn ON-
To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Samsung Customer Support.
RajeshS1414
I am facing green tint issue on my S23 ultra.. what is the solution
arnkmr19
Hey I'm facing the same issue now (18-12-24) have u fixed the issue??
RajeshS1414
No. Samsung is not responding us properly
royyyy
Hi happening for me too
arnkmr19
I'm facing the same issue too.. Have u fixed it, bro??
