S23 ultra Battery drain issue
(Topic created on: yesterday)
Ab455
Beginner Level 3
After one ui 7 update battery drain drastically faster..
8 Comments
SHON_GEORGE
Mani4
Please try to clear cache partition after booting in recovery mode, if not solved format, the device after backup. If it works, you can mark this as a solution, which will also help other users. To do so, click the three dots in my reply section and select "Accept Solution." Thank you!
pappusbg
Ooo
AmitSingh90
Reset your phone
CaptainChiku
Same goes for my S25U
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
