Anu8855
Beginner Level 3
yesterday in
After one UI 7 update, battery drain issues i am facing and phone also getting more heat while using, I am using samsung s21 FE exynos version. Used 86% battery and getting only 2hr 36min screen on time. What the **bleep** going on. Hope u will improve ur service & will provide stable update for it or provide free service.
8 Comments
utkrsh8976
yesterday in
Battery drain hota h new software upgrade se.......ek bar software usage pattern learn kr lega ....fir normal ho jayega
thor09
yesterday in
Reset and use
Anjan_Mukho
Beginner Level 3
yesterday in
I am also experiencing the same issues of battery drainingand heatingup while talking. I an using S24 Ultra DS. I always use power saving mode and battery saving mode.
goodthings
yesterday in
goodthings
yesterday in
Your's most welcome to here.
SampreethSamsun gFan
yesterday in
Bro you have left your phone at 100% for long time. Do you think your battery health will sustain? And also I'm still on oneui 6.1 but I also get same screen on time on exynos s21 fe
gokulll
yesterday in
Im also facing some Heating and battery drain on my S23 after update
Legend_007
yesterday in
I am facing heating and battery drain issue 1 week after installing update. The ambient temperatures are also going above 40°C 🙁
