Resolved! Solved
S23 fe Auto touch problem
(Topic created on: 08-11-2024 04:13 PM)
SinghVampire
I want to know why my new samsung S23 FE screen is automatically working sometime , it auto touches sometimes , please help me i bought this phone 2 days before and facing this problem.
Resolved!
17 Comments
goodthings
Your's most welcome to here.
Oldy47
Get replaced, you paid the full money right you don't need to settle for bad unit.
Aggr passe purre diye hai toh khrab phone kyu rakhna hai, unko bolo yah phone change Karo yah passe wapis.
No bakwas Sidhi baat.
Sandip_119
Bro ap pehele yea check karo ki with charging yea problem ho raha hai yea bina charging ki yea problem ho raha hai. Mere sath bhi same problem ho raha tha jab mein ph ko charge pe laga ke use karta tha kyuki jo charger tha o orginal nehi tha . Uske bad meine original charger le liya uske bad koi problem nahi hai
SinghVampire
I am using original charger , and charge krte time ni , randomly problem aari
Sandip_119
If you like this please accept as a solution....
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue.
Remove the screen protectors and cover from the device once and check the issue after restarting the device.
Path: Press the power and volume down keys simultaneously for a few seconds.
Enable/ Disable sensitivity touch: Settings> Display >Touch sensitivity.
Check space availability: Settings > Device Care >Storage.
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Sanjayrider
Try to turn off touch sensitive
Maaaaiii
No use even after everything
