08-11-2024 04:13 PM in
Galaxy S1 Solution
08-12-2024 09:32 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue.
Remove the screen protectors and cover from the device once and check the issue after restarting the device.
Path: Press the power and volume down keys simultaneously for a few seconds.
Enable/ Disable sensitivity touch: Settings> Display >Touch sensitivity.
Check space availability: Settings > Device Care >Storage.
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
08-11-2024 04:23 PM in
Galaxy S- Mark as New
08-11-2024 04:24 PM in
08-11-2024 04:35 PM in
08-11-2024 04:36 PM in
08-11-2024 04:40 PM in
08-11-2024 04:41 PM in
08-11-2024 05:04 PM in
08-11-2024 05:08 PM in
