S23 Ultra Query Need Solution
(Topic created on: 08-22-2023 09:00 PM)
Abhinav_Sarkar
Can anyone tell me why is this notification showing whenever I'm rebooting my phone. How to stop this notification permanently?
7 Comments
umesh30
Are you trying to open recovery mode??
Hold Volume Up and power button together until phone going to recovery mode.
Now press Volume down button to navigate options and select 'wipe cache partition' and press Power button to select.
When wipe cache partition process complete than select 'Reboot System'.
Finally your device is restart and check that problem fix or not...
Was trying
umesh30
Finally your device is restarting and after that check that problem fix or not...
KarthiM
Always happens in all segment device don't care. It will work as usual
dp075
Power off the device and Power on it again
Rajan_Pandey
Same here
cs_member10
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We would request you to register your concern in Samsung Members Application. So, our concern team gets back to you as soon as possible.
Please report the problems you are facing in your Samsung smartphone with a fresh log file which is in the form of a pdf file/jpg format. And also share a short video clip or 4 to 5 photos along with a pdf file, before and after the issue occurred, for better understanding.
Please share the device log file within 15 minutes of the issue occurrence by using the error report option via the Samsung Member application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Samsung Customer Support.
