S23 ULTRA Battery drain after January update
(Topic created on: 01-20-2025 02:31 PM)
abychan
My s23 ultra battery is going down i. Less than 2 hours after January update. Battery performance was excellent before update. Anyone facing issue?
7 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
1. Perform Battery Optimization: Go to Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage, and Memory
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
SGS23ULTRA
Same problem, but what to do? I guess the only option is to wait till Feb or March for one UI 7 update, which will also have bugs and will have poor battery backup I guess. Then again we have to wait for One UI 7.1 update. Before that we will get used to this screen on time.
Samsung_Qjfa6pe
I updated the software to January batch, and the battery is draining almost 20% faster
Within one hour from fully charging the phone, more than 13% dropped with minimal usage!
A quick fix needs to be dispatched to solve this problem
abychan
Same here. Reported to samsung but they are suggesting some useless steps to and templates
MillersPlanet
How is the battery performance of s23 series on one ui 6? Is it better than one ui 5 on which the phone launched?
