S23 Finger print issue
(Topic created on: 06-19-2024 02:45 PM)
milind3003
Yesterday I bought S23 and put a glass already. The fingerprint is not fast as it should be. It's not capturing my finger. I would say the sucess ratio is almost 5 out of 10. Can anybody help me here? FYI I have already re registered 2 -3 and touch screen sensitivity option is enabled.
13 Comments
milind3003
I also noticed one setting has been removed. The manually adjustment of AOD brightness. Is it removed in OneUI 6.1?
goodthings
Kindly buy and use only Spigen. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
DhruvS23
one workaround you may try. register the same finger more than two times. it will increase the unlock success ratio.
cs_member10
Dear Samsung Member,
As per your concern, Kindly perform the following steps to resolve your fingerprint issue please visit this link: https://www.samsung.com/uk/support/mobile-devices/my-fingerprint-scanner-isnt-working/
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
