07-21-2024 07:37 PM in
Galaxy S- Mark as New
07-21-2024 08:14 PM in
07-21-2024 09:58 PM in
07-22-2024 02:00 PM in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issues.
Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
Galaxy device drain issue: Perform Battery Optimization: Battery optimization helps you to boost the battery performance of your device. To check battery optimization: Settings > Select Device Maintenance/Device Care/Battery and Device care > Optimize > Optimize all options like Battery, Storage, and Memory
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast. We recommend you avoid usage in areas with low network/fluctuation.
Adjust screen timeout settings: Settings> Display> Screen timeout> Select minimum screen timeout.
Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Turn off auto sync of e-mails, app data, etc. We request you to turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
Steps to turn off auto sync are: 1. Swipe down on the home screen to open the notification panel.
2. Turn off the auto sync option.
Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
12-23-2024 12:54 PM in
07-23-2024 03:08 PM in
08-06-2024 09:06 PM in
03-22-2025 10:16 PM in
