06-10-2024 10:25 PM (Last edited 06-10-2024 10:27 PM ) in
Galaxy S- Mark as New
06-10-2024 10:50 PM in
06-11-2024 09:32 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps.
Check connectivity & charger functionality: Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
Note: Kindly open Device Care from Settings > Battery > Please tap on 3dots (more option) at the top right-hand side > Please select settings> Enable fast cable charging.
Kindly follow the standard charging procedure. Charge the device in switch-off condition for a minimum of 10 minutes.
Please check the back panel of your device's physical condition (Bulge, Swelling, or visible damage).
If the physical condition is not good: Request you to turn off the device immediately and please do not try to charge or tamper with the battery also request you to visit the service center immediately.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
