S22 ultra Short battery life
(Topic created on: 05-08-2022 05:24 PM)
MANOJKUMAR_AMBALLUR
My S22 ultra [Snapdragon] lasts hardly half day after a full charge.... I am not using any power hungry apps..just browsing, what'sapp, Instagram..some limited calls..that's all.. Battery life is so poor.Disappointed..😒☹️ What about other owners of S22 ultra?
24 Comments
MrAmJay
When you purchased?
Purchased on 15 March
While taking photos & videos battery drains so fast...
MrAmJay
New device need one or two week to learn usage patter
itsking19
Yeah it may need some time to learn usage patterns, i switched to s21 fe and its battery life was not so great, it took 3 - 4 days to learn usage pattern and it's better now
Yeah..you are absolutely right..but I don't find any progress even after one month
VikrantTambade
Hope you have switched ON the adaptive battery feature under settings. And the processing speed should be set to optimised.
And also put the apps in deep sleep which you are not using.
Hope it should help you.
Good luck 👍
Bdw I am S21Ultra user since more than a year now and I am getting ~6hrs SOT and ~16-18hrs Screen Off Time.
shiv7688
Can you share your battery stats for better understanding please.....
Unfortunately I hard reset the phone yesterday..so the battery status gone..
