S22 Ultra too much battery drain in standby mode
(Topic created on: 04-17-2022 03:50 AM)
S_Kumar73
Yesterday received a Device Care update. After that update I charged to 10% and put it in standby mode. Noticed within 3 hrs 53 mins 8%  gone. Which is extremely high. When I checked the usage, only 4 apps listed 1. Google Play services, 2. Google message 3. Finder 4. One UI home. But when I open one by one from apps settings, every apps shoes battery usage as "0" only.
I really don't know what's samsung software developer team doing. Day by day the update worsening the battery life.
I mainly switched off many settings and put all the apps in sleeping mode. Also did wipe cache and data.
17 Comments
Mr_Seen
My Galaxy m12 has a massive battery of 6000mah,after the update the battery is draining much faster...overnight in a duration of 7-8 hrs the battery drains from 10-15% even if when all the connection like Mobile data, wifi,location&Hotspot are off,Samsung is worsening the battery performance day by day after the update...I noticed many Samsung users are complaining about the battery drain issue if the problem is not resolved quickly then Samsung may lose its respect from many Samsung lovers.
Babuncb
Your Bluetooth and wifi is on
S_Kumar73
I tried turned off wifi, data and Bluetooth, still same result
Same to me my galaxy f62....battery consuming quickly every one hour drain 2%...your phone is dranning very quickly
Babuncb
Mine overnight 5% discharges.
10% drain overnight without use when data is on...🥲
Bro s22 is far batter than ultra
So so so bad👎
The first 10 percent goes down faster in any Samsung galaxy flagship phone. It then stabilizes
