Battery Drain Issue in S24
(Topic created on: 2 weeks ago)
rounakbabi
Beginner Level 3
After updating a 5-day-old S24 to One UI 7, significant overnight battery drain has been observed, specifically a reduction of approximately 15% over an 8-hour period with the screen off. This level of standby drain is unexpected for a flagship device.
4 Comments
MijanBD
Waiting for may security update
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
goodthings
goodthings
Your's most welcome to here.
