saim-sung
3 weeks ago in
I am facing significant reduction in battery performance of my s24 ultra after updating it to one UI 7. No doubt phone has become faster, smoother and more features but at the same time battery performance reduced upto 30% which is really annoying. Is samsung acknowledging this isaue and working on it ? I did not hear anything yet from samsung.
9 Comments
DonpabloGaming
3 weeks ago in
Delete insta fb 80% problem solved
saim-sung
3 weeks ago in
I should buy feature phone instead...all problem solved😂
DonpabloGaming
3 weeks ago in
Insta and fb use 80% of your phone gpu and cpu
30% cpu gpu runs on backgroud even after you closed your app fully
saim-sung
3 weeks ago in
In that case you can restrict background usage
DonpabloGaming
3 weeks ago in
I don't have any battery issue im doing more than 12 hours per day gaming i can play 6 hours constant with 100% delta force mobile still no fps lag no battery drain
saim-sung
3 weeks ago in
Must be using one UI 6.1
DonpabloGaming
3 weeks ago in
S24ultra have 6.1 💀
goodthings
3 weeks ago in
goodthings
3 weeks ago in
Your's most welcome to here.
