Battery draining and heating issue
(Topic created on: 05-21-2025 12:37 PM)
balasankarbalu007
After updating to one ui 7.1 on my s23 ultra the battery is draining fastly and i need to charge the phone twice a day for a normal usage...when i was on one ui 6.1 i was having 23 hrs + of battery standby and now on wons ui 7 im not having more than 7 hrs of battery stand by... ive tried every tutorial and fixing stuffs...
If anyone got any idea or facing the same issue comment
2 Comments
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
Tried all these things and then im reporting my issue
