S21 ultra power button not working after update
(Topic created on: 08-19-2021 09:27 AM)
mittul1234
Power button is not working after August update
Can someone help me fix this
Thank you
11 Comments
Abpal
Head to Samsung members app 》Get help 》start diagnosis 》 buttons.
Let me know the results.
Yes 👍
AndrewJ
This just happened to my S21 Ultra 5g this morning.
Ran the Samsung Members app and it failed the "Press side button" test. All other tests passed.
System software is up to date.
mittul1234
Same
AndrewJ
Update:
My phone basically turned into a lit-up brick (after one of numerous restarts that happened automatically). I then pressed the volumn-down and power buttons for 15 seconds (or so) and that caused a restart. When it came back, everything was back to normal and I could use the power button normally.
mittul1234
My phone is restarting
mittul1234
I can't fix it
Mlear2006
Beginner Level 3
Thanks same thing just happened to me on s21 ultra I did what you said and now it's working
Arpan3791
Thanks, same thing happened to me. Followed your steps, it worked
