01-02-2024 10:29 PM in
Galaxy S- Mark as New
01-02-2024 10:45 PM in
01-03-2024 04:51 PM in
Galaxy SDear Samsung Member,
Kindly follow the easy troubleshooting steps which might help to solve the issue.
Check space availability
Kindly check the space on your device:
Path: Settings > Battery and device Care > Storage
To improve the device performance there should be sufficient space.
Kindly check the RAM in your device:
Path: Settings > Battery and device Care > Memory
The device's RAM should be free to improve performance. So clear the RAM memory once a day
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Close Background Apps
Is there any unnecessary application running in the background?
Too many applications running in the background may cause the device to hang. Kindly close the background running applications in the device (''Tap the left side key & close the background running application'').
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
01-05-2024 10:12 PM in
Galaxy Sgo to setting
1. sound and vibration then system sound then off all sound and go back and system vibration then off all vibration
2. notification then app notifications and off all unnecessary app notifications
3. display than on dark mode
4. display than off adaptive brightnes
5. advanced features than labs off all experimental feature
6. advanced features than motion and gesture off all
speed up your samsung phone
1.first go to setting then
2.about then
3.software information then
4.tap 7 time on build no then
5.developer option open then
6.go back in setting app and
7.last one is developer option then
8.find three type of animation
9.first window animation scale- set off
10.second transition animation scale- set off
11.third animation duration scale- set .5
second tip
go to setting than
display than on touch sensitivity
set samsung mobile camera for best click
first open camera app
tap setting icon
on high efficiency picture
on save selfies as previewed
then setting to keep option
on filters
then go back
tap on filters select ivory -4
than face filter
then tap off/auto
set smoothness-8
set tone - 4
