S21 plus fingerprint scanner not working
(Topic created on: 01-19-2025 12:15 AM)
raaaaaaaaaaaaj
Ever since I updated to oneui 6 my phones fingerprint sensor stopped working, it was registers till 75 percent and then goes to 0, what can i do ? And is it software based issue like a glitch ?
14 Comments
Lemme try it
It didn't help either
cs_member10
Dear Samsung Member,
● Ensure that your fingers are clean and dry.
Note: If the skin on your fingertips is peeling or cracking, or your fingerprint is difficult to capture, the fingerprint ID on your phone may not work.
● If your fingerprints fail to unlock the phone while the phone is recharging, remove it from the charger and try again. If you are charging the phone with a charger and data cable from other brands when you use fingerprints to unlock the phone, they may interfere with the fingerprint sensor and cause the recognition to fail.
● Clean the fingerprint sensor with a soft cloth. Make sure the fingerprint sensor is dry and free from any debris that may cause the sensor to be unable to recognize the fingerprint.
● Remove the current fingerprint and set up the fingerprint again. When you touch the sensor to set up a fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
● How to remove Fingerprint: Path: Settings> Biometrics and Security> Fingerprints> Fingerprint1> Remove> Remove again to confirm.
● How to Set up Fingerprint: Path: Settings>Biometrics and Security> Fingerprints> Fingerprint> Scan your fingerprint> Place your finger on the sensor, then lift it off when you feel a vibration> Continue> Reposition your finger each time to capture the edge of your fingerprint> Done> Fingerprint added successfully.
● Try Safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/?srsltid=AfmBOooat1Wm0...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
