S21 fe mic problem
(Topic created on: 04-19-2024 01:37 AM)
Gowrinandhan
There is a problem with my s21 fe microphone. While recording some back noise is audible but the voice is very low that too audible when spoken loud. The problem is with both primary and secondary mic as well.
There were no physical damages and it happened when I was in a call.
What could be the reason?
cs_member10
Dear Samsung member,
As per your query, please follow the easy troubleshooting steps which might help to solve the issue.
1. Disconnect anything plugged into the headphone jack like a selfie stick, headphones, Bluetooth, etc.
2. Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device. (If any)
Restart the device & Record your voice to verify
How to restart the device
Please follow the below steps
Note: If you use the security feature, the phone will require your backup password to unlock after rebooting.
Press & hold the power key>> Tap on Restart>> Tap again to Restart your phone.
Record your voice by using "Voice recorder" and play the recorded audio
Navigate to apps screen and tap on Samsung folder>>Tap on Voice Recorder>>Tap on recording to record your voice then tap on Stop to save the recording>>Tap on Save>>Select and tap on recently recorded audio to hear the audio quality.
Note: If the recorded audio quality is good, then your microphone is working fine.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. Please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
