Calling Problem
(Topic created on: 05-26-2024 06:57 AM)
ronitghaghada
Can anyone tell me what's the problem in my phone? I have s21 fe If i call someone that person can hear me perfectly but i can't hear that persons voice during normal call. I have checked all the test for mic and speaker 🔊 all are normal and working perfectly fine.
13 Comments
Umangmathur
Try resetting all the call settings to it's default settings and try clearing the cache data of the call app if the problem still occurs try formatting your device also pls make sure that your speakers are properly working try taking a Diagnostic check in samsung members app for your phone. Hope that this information helps you.
If you agree with this solution pls accept my solution for this comment.
ronitghaghada
I tried Diagnostic it's normal and working fine.
I tried restarting phone and resetting call settings too.
But no result
Umangmathur
Then pls try formatting your device or get your device checked in your nearest samsung store and try contacting samsung support.
ronitghaghada
Ok Bro.
MyGalacticGalaxy
Please check WiFi calling feature is enabled or not.
First kindly disable it then check about calling issue. I also faced same many times when WiFi calling is on.
If it resolves your issue please mark it as solution.
ronitghaghada
No wifi calling is off still the problem is not solved
MyGalacticGalaxy
Then please contact to Support team not service center because it's probably an software related issue which can be easily addressed by a security patch.
AJAB_MORIA
Same for earphones ?
ronitghaghada
No brother
