Resolved! Solved
S21 fe 888 switches automatically to power saving mood
(Topic created on: 12-29-2023 03:18 PM)
sanu13g
Even after turning off power saving mood, my s21fe 888 switches to power saving mood automatically. Any way how to fix it
K_K_Y
🐮 mood is not in control may be your phone need a dopamine. Just kidding just turn off the adaptive power saving mode
9 Comments
Go to power saving settings, you can long press the power saving button in the quick settings. When you are in the power saving settings click on the top right 3 dots and click on adaptive power saving and turn it off1703843891849_1703843891843_0.jpg
Let me know if things doesn't work
sanu13g
Adaptive power saving uses the AI technology to understand my usage patterns and works accordingly..as far as I know...
Yes, power saving is turned on or off automatically. You can try, in your case power saving turns on and off automatically. You can also check routines if any routine is controlling power saving
sanu13g
Routines turned of...
i0rish
Well your phone seems to be in power saving MOOD
K_K_Y
sanu13g
But adaptive power saving is that power saving mood which understands my usage patterns using AI and then works accordingly which good for battery life... As far as I know...
cs_member10
Dear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
You can check the device in safe mode and for the safe mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue persists, kindly share the report of the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
