Solution for network switching to 4g
(Topic created on: 08-03-2025 06:07 PM)
arthur27
You might have came across this problem that your mobile data network switch to 4g from when not accessing internet.
After some research and testing i have found that there are these below reasons for it and also provided with solution.
1. Do some basic checks - power saving, preferred network mode, device compatibility, recharge pack details, 5g available in your area, etc.
2. The major reason behind the network is to avoid heating caused due to 5g highspeeds - this cannot be changed from our users side.
3. When device not using internet automatically switch to lower network like lte/ 4g - for this we can have an active usage of data on our device like some yt video/ downloading large file which will force mobile device to stay at 5G network.
Not using actual 5g
Using 5g
If you find this helpful hit the like button❤️
2 Comments
arthur27
It doesn't work!
If i haven't enabled that option how would i be able to 5g then?
arthur27
You can observe the network bar area you won't see solid 5g bar all time.
Same observe when you are actually using internet and not using internet, you can see clear difference.
Thank you.
