** Solution** S23 battery draining fast after one ui 7
(Topic created on: a week ago)
DennisRulz
Beginner Level 3
Iam facing solid battery drain issue after one ui7 update... any fix around it ? @samsung
Update ! Team I found a solution here.. it worked for me....I tried switching off mobile network ( flight mode) for about 6 hours and the battery dropped only 2% ( with network on it was more than 10% ). so I did network reset,one ui cache cleared and battery back up is improved now.. kindly try urs and it may work !!!
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
