Aaryan5796
Tuesday in
Very high battery drain on my device Samsung S22 5G (Snapdragon).
I'm attaching the screenshots of Battery Usage. Mainly background battery is being consumed by OneUI Home & Android System UI. Which is not even close to my last Samsung phone's (M Series) usage.
Kindly please suggest and give solution!
Umesh07
Tuesday in
What is device
Aaryan5796
Tuesday in
S22
Umesh07
Tuesday in
Show me since last charge all aap data
Aaryan5796
Tuesday in
Okay
Zain1999
Tuesday in
Batteries have a life of 3-4 years in ideal conditions. There are some factors you can change to lead your device to better battery health, here are the following:
β’ Use battery saving mode,
β’ Turn off location, mobile data when not in use,
β’ Use battery protection that will limit battery to 85% which will increase the longevity of the battery as conapired to charging it to 100%,
β’ See which apps utilize the most battery are disable background usages usually it is Google play services.
Other factors to keep in mind:
β’ If you dropped your phone, your battery can be negative affected and there is a very small chance of malfunction by consuming more battery.
β’ Using phone outside 15Β°-35Β°C isn't optimal for your battery.
If this answer was helpful, click on the three dots and mark this comment as a solution. Thank you for reading.
Aaryan5796
Tuesday in
Attached screenshots are most usage apps
adithyan10
Tuesday in
New Battery replace karo
BiRdMaN
Tuesday in
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you π
goodthings
Tuesday in
